Pixel strings and strapping
angus40
I have begun the task of zip tieing strings to some strapping . this is a real time consumer .
Here is a tip to save you some time if you plan to use the strapping and tie method.
lay out the string to get it ready to tie , start in the center of the string and work out to each end aligning the pixel wire to lay flat .
There is a little trick you will discover that each pixel will need a rotating flip every so often to get it to a nice flat alignment.
to save on the back , i used a chair and sat at the railing of my deck to do the tieing and let the completed section drape over my railing creating tension on the strapping .
I am using 2 ties per pixel and to secure the strapping to the top and bottom ring i have purchased these clips.
http://www.ebay.com/itm/ws/eBayISAPI...E:L:jawdrop:C:CA:3160
hope this helps
Richard
