Answered Pixel Wiring Advice
Dave_Szoka
Hobart
Morning
I'm currently trying to convert some large Solar powered white Garden Balls to pixels
I have gotten some WS2811 PCD boards
My question is.... I want to mount 2 of these per ball... now I would like to know if i can split the Data coming in so they are both just 1 pixel..
Now I know I can use my F16v3 and just do grouping / virtual strings But i'm hoping there would be away to avoid this
Could I split the Data coming in to the start of both pixels but then only come out of 1
Thank you brains trust
You "shouldn't" have any trouble doing this. If you are running longer distances between "pixels" then it might present a problem but if under 10m from F16 and less than 3-5m between pixels you should get away with it.
Dave_Szoka
Hobart
Thanks Alan
Maybe I should add some null pixel buffers to help.... now where can I get those
Dave_Szoka
Hobart
Why not use Dumb RGBs?
Hey DJ
That would mean 12x 4 core cable runs back to my controller....
Plus during the off session these will be in my garden running off a PI
If I can’t make to it work, I’ll just go with one
Dave_Szoka
Hobart
Thanks Alan
I would suck it and see whether you need them. Easy to add after you've knocked a couple up to try. Link on my signature to my website and I have lots of the nulls in stock. They will definitely allow you to drive into 2 parallel pixels.
Dave_Szoka
Hobart
Well I kinda went another way.. I needed to order some more bits from ray so also order some 3w 2811 leds.... 1 of those per large ball ... much easier
