So I am giving my first go at a mega tree. I am using 12V Pixels off of a falcon differential receiver. I have 12, 50 node strings arranged in groups of 4 using the first three outputs on the receiver. The last will be used for either another set of 4 strings or a star later down the line. the issue I am running into is that the 2nd and 3rd group of pixels are assigning themselves in the wrong order. The first 4 work fine, the next four are backwards - what should bring string 5 is lighting up for string 8. I have string 5 connected directly to port 2 on the differential and then the next three string are connected together, its the last of the 4 strings connected together that lights first and works as sting 5 on xlights (when in reality it is the 8th string). The last group of four has the same issue.
The obvious work around is to physically rearrange the 2nd and third groups so that they light in the correct order but that seems like a one time fix instead of solving the route of the issue. What am I missing here? I have checked the pixels and I am going the correct way with the data. I am doing nothing different with the first group of four that is behaving properly. I tried as both a mega tree model in xlights and as setting up 12 individual strands. Both ways they light up out of order. It makes no sense to me but I must be missing a stupid issue.
