PixLite Configuration Video
ltay13
Eastern Melbourne
This is a clip showing the main features of our configuration utility for PixLite controllers. Our goal is to have a central management system rather than remembering IP addresses and using web browsers to configure pixel controllers.
Utility Tutorial
kane
Very impressive configuration - looks very easy.
So I assume that you can only use one pixel type on a controller? Obviously not a big issue in most situations, but sometimes you find yourself needing to use multiple protocols from the one controller.
A test mode would also be pretty useful?
ltay13
Eastern Melbourne
Correct only one pixel per controller. We have thought about this a lot but for the foreseeable future that will not change. It is *possible* that in the future this will change, but it is not a simple task when outputting such a significantly higher volume of data than most controllers normally do.
We may actually release a smaller capacity board for a cheaper price instead and forget about running multiple ICs at the same time altogether - FYI.
As for test mode, yes it is on our to-do list. It will be happening very shortly.
kane
Yeah, fair enough. In any case, most people wouldn't have a need, especially those starting out now, as 2811 seems to be all that anyone is buying.
And a smaller capacity board would be good, to give people options.
Looks like a winner of a product.
