Good evening, this also happened last night on the first night of the display.
Setup : Laptop running windows, F16V4 with a F16V3 daisy changed using an ethernet cable for data and xschedule.
In testing all props worked, with both controllers as expected. However when it was "show time" had audio but no lights.
What have I done :
Ran the sequence in xlights with the V4 and a test string operated as expected.
Using Test on the V4 web page selected the appropriate port test string lit. Good
Test with Test in xlights again test string lit.
Did a batch render of all sequences, then replaced FSEQ file with updated file, again selected the sequence in xschedule, play no lights.
Problem when xschedule plays a sequence no output from either controller, but we do have audio.
Any suggestions Thanks
Burto
What have I done :
Burto
