Please confrim D2 settings.
cwbotner
Winsted, MN
[attachimg=2][attachimg=1]All;
please confirm my D2 settings. I am getting the red light on the LOR controllers, but no blinky blink.
Thank you,
Collin
Your second universe is setup incorrect
The universes 1, 2,3 and 4 are for hyper DMX which you are not using so you only use the 1 universe 1 row for both outputs.
So if you have your software to output universe 1 and 2 then have output 1 as universe 1 (which is correct) and then output 2 as universe 2. Dont use the addition universe outputs in the D2 configuration as mentioned before this is for hyper DMX which you wont be using
First issue I can see is you have universe 2 set for output 2, but no universe 1. Form normal use, only use the universe 1 column on each output.
I'd also disable the Keep-Alive while testing as that can create issues if set incorrectly.
Lor have been using Port 1, I tried port 2, and tried 1, and 1 in the univ 1 slot. I have been making changes, to try and trouble shot the issue
[attachimg=1]This is my LSP setup for the LOR over DMX output. Please confirm. Should be pretty straight forward. universe 1, start 1, 512 channels.
Correct?
I tried to seperate the channels in groups of 16, but that did not work, so I just set the 1st one to 1-12 and turned off the other 3.
Fair enough. The fact that you can't get it to work with da_E131 suggest an issue with the D2 configuration or the controller wiring.
Just make sure LSP output is not active when you run da_E131 and visa-versa.
[attachimg=1]Here is the output config. Only e1.31 set.
