Hi I'm a new guy and I'm doing all my research and putting everything together but I had a question about power Injecting, if I'm using a controller to power the first set of pixels in a run and want to power inject after that do I use the second set of power terminals on the power supply powering the board ( and this would be using positive and negative) or do I use a new power supply and just use the positive?
Thank you
Thank you
