Pre-made Mega Trees
DMX512
Huuuuuuge Nerd
Hi all.
I am trying to find, are there any Australian pre-made or already designed mega tree kits?
Obviously not plug-and-play, but any kits of everything I’d need?
Preferably under $200au
Hi all.
What do you mean by everything you need? $200 'might' get you a topper and a pole but obviously won't get lights, mounting strip (if required) and all consumables... most pre built kits are USA based at moment and all over $200 before you even think about shipping them...
That sort of budget lends itself more to DIY and repurposing stuff eg frying pan topper, used acrow prop pole etc than a purchased kit...
but all depends what you are wanting for your money...,?
This was my list/cost when i built my mega tree. Approx 4.5m high, 32x150pixels. Costs are without pixels/controllers etc.
Mega Tree Related
LightitupMounts Strip 12mm pixel nodes - 50m Roll
AmazonBungie Balls - 6inch x50
Piptree DesignsTree Topper
KoganHand Winch - strap 680kg.
Hanson ElecPixel Strip Relief Mount
BunningsPaint - Black Zinc 2 coat paint for topper
Midalia SteelSteel Pole/s - 20NB (26.9x2.6), 40NB (48.3x3.2) , 50NB (60.3x3.6) Med Gal Pipe x6.5m lengths
AliExpressM5 Sheep Eye Screw bolt ring hanging hook x35
BunningsConcrete
Safey ExpressBase Flange & Hinge Male Part + Shipping
AutobarnExhaust Claim 57mm 2 1/4Inch
BunningsConduit 50DN
BunningsConduit 50DN Lid
Fastener FactoryHEX SET SCREW
(FULL THREADED BOLT) A2 (SS304) M8 x
130mm - 25pc
Fastener FactorySS HEX NUT A2 (304) M6 -
100pc
Fastener FactorySS HEX NUT A2 (304) M8 -
100pc
Fastener FactorySS FLAT ROUND WASHER A2
(304) M6 x 12.5 x 1.2 - 100pc
(304) M8 x 17 x 1.2 - 100pc
Fastener FactoryUltraSafe Earmuff Red Premium
Insulated Class 5 (34dB)
Fastener FactorySTAINLESS STEEL WIRE ROPE GRIP A4
(316) M4 WIRE - 10pc
Fastener FactoryTurnbuckle Hook/Hook A4 316 M6
Fastener FactoryWire Rope Thimble A4 316 M4 Wire
Fastener FactorySS WIRE ROPE 7X7 A4 (316)
M4 (25M)
Fastener FactorySS QUICK LINK A4 (316) M6
Fastener FactorySS SQUARE EYE PAD A2
(304) M6
Fastener FactorySS EYE BOLT WITH NUT &
WASHER A2 (304) M6 x 80mm
WASHER A2 (304) M6 x 40mm
Fastener FactorySS HOSE CLAMP WORM DRIVE
A2 (304) UNIVERSAL SIZE 4 70 - 90x12mm
Band
A2 (304) UNIVERSAL SIZE 3 50 - 70x9mm
Band
Fastener FactorySS D SHACKLE STD A4 (316)
M6
Tentworld500mm Beach Screws
Tentworld500mm Beach Screw Kit (with 2 screws)
Total cost (2023) was $1,294 for a DIY version.
Here was a bit of a build guide on what i did
ouch thats pricey,
I just got a 3.5m pole for $40, the topper for $50, then power supplys @ $200, then controller avg @ $200+ , then its the pixels an strapping for the pixels.. say $500
Ok @Johnnyboy was right with his pricing..
To hit your $200 mark, goto bunning's an buy one of there crappy tree's for $200-300
There are places in America that sells MegaTree Kits, but you wont like the price. https://yourpixelstore.com/product/mega-tree/
Twinkly are doing a 3 metre tree for 500. 1000 pixels.. can be run from xlights
Ah…
I seem to have wholly misjudged the cost of a mega tree.
I was hoping for everything (controllers and pixels as well) under that price range, but if that is unreasonable, I might not be able to.
I found it easier to simply not calculate the cost, I built one one year out of the black strip and bullet pixels from AliExpress and controlled it with an ESP type controller and used a palm tree out the from with a bunch of screw in hooks to hold it all up. Was it the best? Nope, did it work and was it functional...yep. Then we decided to remove the palm trees so my pole went with it and i just had all of the strips rolled up in milk crates in the shed. Ive only just started thinking about making another as it was pretty spectacular in all honesty and really made the effects from xlights pop but damn it feels like a lot of work not that i look back on it. I even still have a whole roll of the black bullet pixel mounting strip in the shed i didnt even open .
