Habbosrus
Back again
You can buy a RTC (Real Time Clock) add-on board for the PI. I am currently researching this option.
DannyP said:I too have ordered a Pi today and this looks so easy to set up. So if I didnt have a wifi connection avialable, does this mean that I cant run the Pi as it wont know the time and hence the scheduler cant run? Or is there some other way of getting around this?
mkozik1;274282 said:Got it - Like I said, bad thing!! Was thinking of something else .......
Thanks,
David Pitts said:You can find the first public Alpha Release here. Alpha 0.0.3
http://sourceforge.net/projects/falconpiplayer/files/FalconPiPlayer_Alpha0.0.3.img.zip/download
We are getting the bug tracking system set up. We may end up using Github's ability to track bugs.
Known things to implement/bugs
1) Repeat/no repeat of playlists in immediate player.
2) First/Last option for playlists.
3) Weekday, weekend and other quick scheduling day options.
4) Better music to sequence data syncing.
5) E131 to Pixelnet/DMX bridge. (Half way done)
6) Video playback, wireless slave operation.
Follow the instructions here to get the image burned to your SD card(4gig minimum). You also need to have a USB memory stick formatted to Fat32 installed in PI to hold media.
http://www.raspberrypi.org/downloads under Raw Images. But use our image instead.
This release is to get you familiar with player and possibly to allow a willing user to create a wiki and/or manual.
This is an Alpha release and will be a bit buggy. This is still a work in progress.
Thanks for your patience.
David and MyKroft
