Stkilda123
Hi, i've started my setup and put my 16 string mega tree up, which seems to be running fine, being run off 4 smart receivers which is connected to F48,
My problem is i've next connected my star, gingerbread man and some stocking to another smart receiver and that is where the issue is starting, only some of the lights are turning on in the sequence,
I tested them via the smart receiver test button and then they all turn on,
When i test through FPP they start playing up again, if i go onto the star and try and test that, the gingerbread man comes on a little, but nothing on the star, same as when i try the stockings, but if i try and test the gingerbread man nothing happens. And yes they are plugged into the correct input.
Any suggestions would help, obviously there is some communication problem between FPP and the receivers, but i don't no what to do to locate it or try and fix it,
Here is a photo of my channel set up if that is needed
