That was an idea and I may do it. The tube just has to be steep enough for the sand to slide down. I'm 6'3" and I still need a step ladder to do it and that's with the end of the tube on the ground.lizardking(adam) said:can you make a tilt table with your form on it so you can tilt the table to fill then flatten the table out and put in the form
Bevo said:After looking at the guys heat snake. It looks like you could make one using a drain heater maybe like this one http://www.ebay.com.au/itm/PVC-DRAIN-HEATER-REPTILE-EGG-INCUBATOR-FREEZERS-SIZES-120W-80W-40W-240VOLT-/261093984144?pt=LH_DefaultDomain_15&hash=item3cca6a0790 and placing it inside the right sized flexible steel corro like this http://www.ebay.com.au/itm/111402849001?clk_rvr_id=816859528534&crlp=1_262691&mt_id=641&mid=503315&sdc_id=1429443318z408587z4e073b0a25252z&fitem=111402849001&linkin_id=8084735&kw=%7Bquery%7D&crdt=0&sortbid=8
flexable larger conduit coild be an older vacuum cleaner hose
The flexible conduit would have to be close to the internal size of the tube and the flexible conduit will get very hot like in his video.
Might be an option?
