Closed Purchase milky white 50mm x 3m acrylic tube
mborg10
Michael Borg
claremont meadows
The tube is here safe and sound. Please be patient with me as I just started my new job yesterday. I will send pm's on the weekend to get postage, put the tube into bundles then organize price for shipping and pm you again.
B_P_J
Wadalba
Legend.... Cant wait to pick them up.... woohooooo they look great too... watch out for my comment in that post
mborg10
Michael Borg
claremont meadows
Any locals that want to pick their tunes up this weekend. I'll be home after lunch Saturday 18/04
mborg10
Michael Borg
claremont meadows
200 tubes now stored safely in the garage.
mborg10
Michael Borg
claremont meadows
I did some testing today on the acrylic tube to get it to bend into an arch. I made a form up using the lid of the shipping box.
first attempt - I had the tube empty and heated it with a heat gun. The acrylic was bending nicely but then it put a pretty decent kink in it. I quickly rotated the tube 180 and was able to bend the kink out before it hardened. That method just was give a good enough result.
Second attempt = I filled the tube with sand. I now had a 3m long 10 kilo wobbly tube that I had to support at both ends. The heat gun this time took forever to reach any sort of bendable temp and I forced it to hard and cracked the bottom of the tube. The sand inside, even though dry was drawing to much heat away from the tube and it would not reach a bendible temp.
Third attempt - This time I tried to heat the sand with the hot air gun. The hot air gun couldn't heat the full amount of sand required for the tube and it really burnt when it rolled down my arm.
Future attempt and what was always my original plan. Heat the sand in the oven, pour inside tube and bend around form. (As seen on youtube) I just have to make a support for the tube while pouring the sand in as the hot sand will cause it to bend prematurely.. Something to hold the tube as Im bending around the form and it has to be nice and easy so I don't burn myself.
It may sound like a bit of fiddly work but trust me the videos doesn't do the tube justice. Even my wife said it looks awesome and was worth the effort. She is sick of me talking about all the hassles of shipping "Acrylic Tube"
lizardking
IT IS STILL ALL BENS FAULT
Gold Coast
can you make a tilt table with your form on it so you can tilt the table to fill then flatten the table out and put in the form
mborg10
Michael Borg
claremont meadows
That was an idea and I may do it. The tube just has to be steep enough for the sand to slide down. I'm 6'3" and I still need a step ladder to do it and that's with the end of the tube on the ground.
nzlongfellow
Dennis from NZ
Lepperton, Taranaki
My adventures for what it is worth.
I made some 1.2m dia circles from 25mm conduit. Heated the sand on the gas stove top.
It was very difficult to get the sand the correct temperature then pour it in, and get it full. Then allow time for it to soak (heat thru) before bending, and it did a reasonable job.
Seeing you have so many tubes it may be wise to invest in a heating snake that everyone can use.
Any element manufacturer would make one. Put a current control on it and dial up the temperature u want, do your bend then allow to cool. Like this guy.
Hot Snake Bender Full Demonstration or
How to Bend PVC 001 - The Basics
Just my thoughts.. 8)
OR Make one of these LOL "SPEED 5500" BENDING PVC PROFILE(Гибка ПВХ профиля)
mborg10
Michael Borg
claremont meadows
Sounds expensive and couldn't find anything in Google.
Another method I have seen is to heat it with steam but that doesn't solve the kinking.
I'm going to keep pushing with the sand method as you don't need to use as hot of temp to bend acrylic as you do PVC. 130 degrees will soften acrylic.
Bevo
Let your Light Shine before men
Caboolture QLD
After looking at the guys heat snake. It looks like you could make one using a drain heater maybe like this one http://www.ebay.com.au/itm/PVC-DRAIN-HEATER-REPTILE-EGG-INCUBATOR-FREEZERS-SIZES-120W-80W-40W-240VOLT-/261093984144?pt=LH_DefaultDomain_15&hash=item3cca6a0790 and placing it inside the right sized flexible steel corro like this http://www.ebay.com.au/itm/111402849001?clk_rvr_id=816859528534&crlp=1_262691&mt_id=641&mid=503315&sdc_id=1429443318z408587z4e073b0a25252z&fitem=111402849001&linkin_id=8084735&kw=%7Bquery%7D&crdt=0&sortbid=8
The flexible conduit would have to be close to the internal size of the tube and the flexible conduit will get very hot like in his video.
Might be an option?
lizardking
Gold Coast
flexable larger conduit coild be an older vacuum cleaner hose
Might be an option?
Fing
Muswellbrook
Hi Everyone,
don't hold me to it, but after watching the videos, I may be able to "find" some industrial trace heaters….. give me a couple of days… if what i'm thinking works out, then we could all mail it to each other and share it……then Michael can have it to clutter up his garage..
but I am on dogwatch and it is 2:49am, so i reserve the right to make stupid statements…
Michael, what is the internal diameter of the tubes ?
Fing
mborg10
Michael Borg
claremont meadows
I just ordered some bubble wrap for packaging after getting the ok from "smart send" The storm put halt to any work this week.
