Question about the PixLite 16
Discussion in 'Advatek Lighting' started by tmarshal61, Oct 26, 2013.
  1. tmarshal61
    tmarshal61 New Elf
    Oct 14, 2013
    20
    0
    HI,
    I am totally new at this so, please pardon me if I ask some silly questions. I just purchased the PixLite 16. I have 20 - 150 pixel 5V WS2812B RGB strips and 3 - 50 pixel 5V strings on order. I plan on creating a 2D mega tree with 12 strings or so and use the others for arches and various other things.
    The PixLite 16 has 16 separate outputs and each is capable of controlling 340 pixels so, I could conceivably run all of my lights on just 11 outputs if I run two strips per output. I understand that power injection might be a requirement but, other than that, is there any advantage to spreading the lights across all 16 outputs rather than doubling them up? The major advantage I can see would be that doubling up the strings frees the other outputs for future expansion.
  2. kane
    kane Dedicated Elf
    Dec 23, 2010
    1,033
    9
    Yes, that will be fine.
    The main advantage of having less pixels per output is that if you get a dead pixel along the way, then you get less pixels go down (as the pixels after this one will usually stop working).
    This is more relevant to pixels (especially those that may have dodgy waterproofing), so less likely with strips.
    Kane
    ps - no such thing as a silly question in here (as long as you've done the basic search first and you've read FastEddy's great 101 guide)
  3. ltay13
    ltay13 Full Time Elf Community Project Designer
    Jan 2, 2012
    121
    1
    Eastern Melbourne
    That will work fine, the major disadvantage apart from the potential outage of a pixel failure than Kane mentioned would be power injection itself. If you are happy to inject power where required then go for it, and give yourself room for expansion later.
