@merryoncherry thanks - maybe I'll keep an eye out for the next order.
@JacksonHo great find, I'll add to the next jaycar shopping list
@JacksonHo @DarkwinX - Look around for the proper 3M/Corning UY2 connectors. Those are the "original" ones that are used by the telcos, rather than some knockoffs.
That said, if you're going to go down the cheap path - check out eBay - you can get 1k for $99, or 100 for $15, so a fair bit cheaper than Jaycar.
UY2 Twin Blade 2 Wire Scotchlok Scotch Lock Gel Filled Splice Crimp Connector | eBay
UY2 - Gel Filled Splicing Connector. No wire stripping is required and connectors will accept wire of the different gauge. For use with solid copper conductors only. Perfect for pigtail and load coil splice applications.www.ebay.com.au
I have used both and found that the originals keep longer - the cheaper ones the gel goes off faster when in storage. Not sure how that translates to real-world performance, however.
Turkies have them - although you need a login for priceThanks Sky - great info
Do you also have a link to some originals as well?
Thanks - seems like Middys have them I'll take a lookTurkies have them - although you need a login for price
Other electrical suppliers will also have them.3M Scotch | 3MUY2B | CONNECTOR IDC UY2 SCOTCHLOK YELLOW BOX [200] | John R Turk Electrical Supplies
Weve got CONNECTOR IDC UY2 SCOTCHLOK YELLOW BOX [200] at wholesale prices at Wholesale Electrical Supplies l John R Turk - Register Now!www.jrt.com.au
I used these on my sprinkler system. Have not had one fail yetI've been doing the quick and nasty red crimped connectors but the failure rate means I'm going to start soldering the ones on the ground. The main issue I have is the roof so I am thinking of getting these from Jaycar. I have seen them used by Telstra and NBN people so they must hold up okay until I get all the props down at the end of the season and solder them.
Crimp Wire Connectors Pack of 50 | Jaycar Electronics
A straightforward joining solution for your wire coupling needs. No soldering required!www.jaycar.com.au
