Rebuild failed error
Madko
Castle Hill NSW
Hey guys,
I am at near completetion of my 2014 program when I went to save it and it wouldn't save. It came up with something able unable to save effect channel.........
When I closed it and tried to reopen my latest save program I got ' rebuild failed on christmas_2014_EFFECT, isam_err=37, sysiocod=112.
I closed the program and reopened it in administrator and then tried to open a known good previously save file. It's is it required rebuilding effects which I excepted. It rebuilt effects and opened up. However all the programming I did (which was nearly complete) was all missing.
When I scrolled along the song time line looking at a channel I then received this error,
Paint E Guid not found
Let joe know what effect action you did just prior to this message.
Roof line 4 - #_0001- time tic 8576
I was wondering is there hope for me retrieving my program somehow? And how do I do this.
Thanks guys
jcmarksafb
Try going into windows explorer and renaming your .hls file to a .bak file. Then rename one of your latest backup files to .hls vs .hls1. This should make your backup file the one that HLS is looking for. Hope that helps.
John
Sorry, not too clear, rename your current file to (your file name) .hls to (your file name) .bak then find your latest backup which is a .hls1 file to what (your file name) deleting all of the numbers behind it and change the attribute from .hls1 to .hls. Hope that's clear enough
Madko
Castle Hill NSW
Hello,
Thanks for your reply. Last night I tried changing a known good saved file and changed the attribute to .hls but I didn't change the original to a .bat. It didn't work anyway however what does the .bat part do to make it work. I just don't understand that part. Cheers
Madko
Castle Hill NSW
So I change original to a .bak attribute and a know good save to .hls but when I open HLS program in administrator and open this file I'm still getting the error
Rebuild Failed on christmas 2014_effect, isam_err=496, sysiocod=112
Where do I go from here?
I thought my version of HLS which is version 14.U was corrupt so I tried and opened up last years sequence and this opened up no worries! So I thought I can count the program out?
Thinking back about what I was doing just before I had these issues and I just added an effect group into the library and tried to save it. However since we are trying to open a file prior to this problem and it's still not opening I'm completely lost and worried all my hard work in sequencing is gone.
Fingers crossed I can get a happy result!
Madko
Castle Hill NSW
Problem Found!
Lack of storage on hard drive. When i saved my program it only saved half and when i reopened it up along came all the errors.
Over the course of programming i now realise what joe means now by clean up weekly under the file heading.
Anyway thanks for your help.
jcmarksafb
The reason that I chose .bak was just to mark it so I could remember that that one was the one I was having trouble. You could have don .bad or anything else. I have had the same problem with HLS, it dose not tell you that the disk is full and will only save a portion of your new file. HLS makes a backup file every time you save so your disk can fill up quick if you save a lot (which you should do). You are working with a very old version of HLS, I would suggest you download the newest version, there have been a lot of changes (for the better). I'm glad you found the problem, I've been there and have had the same sinking feeling that you had of loosing a lot of work.
Have fun
John
Madko
Castle Hill NSW
Yes, it's a terrible feeling especially when I was 99% complete and was just cleaning up a few thing.
If I up grade to the new version will I have issues with my sequence opening in a new version etc? Or is everything good?
Off the top of your head do you know what the extra things are with this newer version versus the one I'm using?
Thanks again john for your input. I'm always learning
Habbosrus
Back again
Swansea, NSW
G'day Madko,
Your sequences should open fine in the new version. You mentioned you were on 14U. That was released 12 months ago. That's a long, long time in the HLS world. Joe has been a busy boy since then. There are a lot of new "things" since your version. I have most of the versions if you want to take a few steps at a time, although I did miss a couple over the past few months.
9/7/2014 Version 20V Clean Effects -- background channel nor present caused crash. 9/7/2014 Version 20U Group Clip and Fill - now remove selection box 9/7/2014 Version 20T Added Ramps to Animation Eye Effects 9/5/2014 Version 20S Remove Unused Effects from DB did NOT include Background effects so they were removed --- now saves active FG and BG effects 9/2/2014 Version 20R Added BGR 8/25/2014 Version 20Q When added Matrix to Preview -- did not init ptr to Matrix which resulted in Hang when closing from Preview 8/11/2014 Version 20P Test Matrix in Preview - found 3 memory blocks not deleted 8/8/2014 Version 20N Made Black mouth/eye matrix colors show background 8/7/2014 Version 20M Added check in animation to make sure Matrix channels are ALL assigned before coloring specific mouth/eye positions 8/5/2014 Version 20L Crash report -- Animation attempting to set Matrix channels with xatrix size of zero 8/4/2014 Version 20K Made Sticky channels to be removed 7/30/2014 Version 20J Allow audio to be displayed if only 1 STICKEY channel is specified 7/30/2014 Version 20H Animation Vocals Dialog -- not listing multiple Face Names properly. 7/29/2014 Version 20G SantaCarla crash -- Animation Eye init -- array zero 7/28/2014 Version 20F Animation Pixel Matrix - when changing matrix size - remove previous work. 7/28/2014 Version 20E Eye - Matrix Pixels -- added ask if want new eye position 7/28/2014 Version 20D Crash fix - add effect to Mouth -- missing test for channel not found 7/24/2014 Version 20C Added Pixel Matrix Animation 7/20/2014 Version 20B Added ability to set starting channel, ending channel and skip values when dropping an external effect on to RGB 7/20/2014 Version 20A Added ability to Skip starting TICS when using NC effects 7/4/2014 Version 19Z Added RBG 6/13/2014 Version 19Y Santacarl crash with Green Tic near end of sequence... sprintf passing double printed a decimal -- size mismatch 6/12/2014 Version 19X Allowed Start TIC to be set at position 1 6/12/2014 Version 19W Allowed External (NC) effect to be started in cell 1 instead of 2 --- same with PP effects 6/8/2014 Version 19V Crash reports had stopped -- Changed email to new encrypted email server 6/6/2014 Version 19U Forgot -- so added fix to Preview Only Editor's Grid -- ignore lighting, Special (triggers, mouth, face), and expanded PP and Segments 6/5/2014 Version 19T Added Preview Only Sequence Grid Channels (Al's request) 6/4/2014 Version 19S Added Matrix to Preview 5/5/2014 Version 19R Added Export/Import of Animation Eye Data Enabled the capability to Delete a Library file 4/14/2014 Version 19Q Rich says NC effects load one channel off. Found my indexing was bypassing first channel. I did not test - hoping rich will. 4/11/2014 Version 19P Fixed GIF frame delay 1/5/2014 Version 19N Added Inc/Dec to Prepare Channels for Output 1/3/2014 Version 19M PlayList XML Parsing improved to remove xml file size constraint. 1/2/2014 Version 19L Added Text Based Error code acquired from XML Component Show Parse 1/2/2014 Version 19K Added debug Filename and error code to Show XML File read error 12/27/2013 Version 19J Added Segment build test for background info - crash fix when Segment has BG but some do not 12/27/2013 Version 19H Added test for Segment associated channel being Active - not just existing 12/25/2013 Version 19G Prevent user from engaging Preview or Output if in PixelPlane Editor Prevent user from having access to Right-Click menu if Preview active 12/25/2013 Version 19F Gray'd out Manage Channel Menu when Preview Active -- User trying to use when not suppose to. 12/25/2013 Version 19E Added Path to Library File Open Error Messages 12/23/2014 Version 19D Revise Fore/Back Ground to NOT Scroll top of Group when Mode is switched 12/23/2013 Version 19C Added OutputOrder to Library Import (was missing) Fixed Show Schedule root of HLS Fixed Show Audio Level to perform Playlist Volume level 12/18/2013 Version 19B Fixed Bad buble sort index when Assign Channel to Pixel 12/17/2013 Version 19A Added Remove and bot Top2Bottom and Bottom2Top to Single Cell PixelPlane Channel Assignment 12/16/2013 Version 18Z Added Single Cell PixelPlane Channel Assignment 12/15/2013 Version 18Y Revised CSV --- made sure Channel Number was being included - not Background 12/13/2013 Version 18X Library Segements replaced from Guid to Channel Name -- Now works as desired 12/12/2013 Version 18W Added Preview Position check for negative position which would lock in min mode 12/10/2013 Version 18V Revised NIC Verify in SHOW mode Added Batch SHOW launch 12/09/2013 Version 18U Removed Auto bump scroll Added DEFAULT setting for CTRL Bump H-Scroll Added Audio Level to Show 12/08/2013 Version 18T Added Quater page move left/right with cursor at window boundry Added ALT Home/End to move Grid Vertically 12/07/2013 Version 18S Removed Mouse Capture in Grid View so user can use scroll bar while in selection 12/07/2013 Version 18R Added ALT-E hot key to modigy one or more effects Added Associate Display Groups to Hot key via Dialog under Defaults Increased Number of Universes Added Critical Section to Show Clean/Stop output process - race 12/06/2013 Version 18P Added Red-Green Ruler Marker Time Delta 12/06/2013 Version 18N Added Over-ride on Show/Playlist to NOT turn lights off at end of song 12/06/2013 Version 18M Added Debug Message box for Display Group F key association 12/06/2013 Version 18L Added addition check code to help locate Preview Background image if User changes computer 12/05/2013 Version 18J Added User set NIC that does not exist on computer - ask to set again 12/05/2013 Version 18H Added Copy Past acrosss Display Groups Added 4 hot keys to switch between Display Groups 12/05/2013 Version 18G Added Modify Multiple effects 12/05/2013 Version 18F Added Convert PCM to WAV Added Copy/Paste to Transport/Protocol assignment Engaged Background DirectX Error MessageBox 12/04/2013 Version 18E Added PlayOnce to Show and Playlist Added "Turn All Lights OFF" at completion of song for Show or Playlist 12/03/2013 Version 18D Fixed Load PP Directory bad header (missed break) Fixed Chase pull corner - referenec Y component instead of X -- Copy/Paste goof 11/30/2013 Version 18C Fixed Nutcracker to PGN Pixel Mapping 11/30/2013 Version 18B Revise User Interface Dimming Curves Added DC Line Segment Added DC Grid Scalling Revised RGB DC File format Added RGB Dimming to Export process 11/29/2013 Version 18A Added External HLS Effect or Nutcracker effect conversion to series of PNG files 11/29/2013 Version 17Z Removed one instance limitation --- run multiple Added Throw arg to new so return null added flag to linker to provide 3 gig to win32 machines 11/28/2013 Version 17Y Expanded Recent Files Added Heap Alloc directly 11/25/2013 Version 17X Added PixelPlane detail info to Library 11/24/2013 Version 17W Revised Preview Edit of Custom to show work after initial creation 11/22/2013 Version 17V Revised Audio Tail Attenuation -- From GREEN Marker 11/21/2013 Version 17U Revised Segments to work with Background 11/20/2013 Version 17T Added Audio Tail Attenuation 11/19/2013 Version 17S Fixed Fat Finger (Copy Past from Sub Lighting) - broke Master Made Color Button Names Reverse color Added to spaces to Group Names in Left Display Panel Removed Sizing Buttons from Preview 11/15/2013 Version 17R Added Backgrounf Merge test to make sure all memory array are valid prior to merge 11/15/2013 Version 17P Added Background to Preview -- don't know how I missed this earlier Added Hot Keys -- ALT 1,2,3 for Level Effects. Added ability to copy Lighting Segments effects 11/14/2013 Version 17N Removed "Modify List" when dupping a Seg because its not created yet 11/14/2013 Version 17M Found Serialize WorkGroup Buffer too small - crash 11/14/2013 Version 17L Fixed Lighting Master RGB Intensitty bug 11/13/2013 Version 17K Added Slower Audio rates to Play. Added 3 set color buttons on Work Panel Added track 4 windows positions. 11/11/2013 Version 17J Added ability in Raw Channels to Auto INC Universe Numbers when Renumbering them 11/11/2013 Version 17H Added Audio Level Control -- Audio level is Exported to Play Show Also 11/11/2013 Version 17G Made Color Shift to be selected by specific color picker instead of color wheel 11/9/2013 Version 17F Changed Channel add to Group max from Max Group Channels to Channels in Grid - Bug Fix 11/9/2013 Version 17E Crash found hole when deleted BG channel -- still wrote BG data and crashed on load 11/9/2013 Version 17D Added Custom Effects (Random and Chase) to be dropped on Segments and placed as seperate channels 11/8/2013 Version 17C Increased number of Segment Channels to 20,000 11/8/2013 Version 17B Added ability to select size of Custom Preview Effect 11/8/2013 Version 17A Fixed missing RGB arrays for RGB added after From Raw Channels and Vixen and LOR Conversion --- caused crash Fixed Background in Grid View. Working correctly in output but View did not allow Background to come through on Black. 11/7/2013 Version 16Z Added "Always Build" flag in upper right corner -- removes asking if want to build output and assumses YES 11/7/2013 Version 16Y Fixed Assignment PixelPlane Verticle Made Audio Hot Key Accelerators 11/7/2013 Version 16X Removed Grid update call when building PP effects for output - killing RGB data making not visable Fixed color button index access from index 4 to 3 11/5/2013 Version 16W Added Background capability 11/5/2013 Version 16V Added user custom color buttons Revised PixelPlane Channel assignment to name match only 10/29/2013 Version 16U Added test for HLS and LOR resolution being the same 10/29/2013 Version 16T Allow Grid during Output 10/28/2013 Version 16S Fixed DMX specific output value Revised Chase to GROUP and Chase Implemented Mirror (V and H) for Segments 10/27/2013 Version 16R Added Bulk Color select to Raw Channels 10/27/2013 Version 16P Added Mouse Scroll Horizontal 10/27/2013 Version 16N Added Universe to E131 Socket init error message for debugging 10/26/2013 Version 16M Fat Finger mistake in Audio function affecting Preview 10/26/2013 Version 16L Added Magnification Fixed Save Crosshair Cursor not appearing Tested for Negative BitMap Y size Moved Audio Red bar mid tic When changing grid size - set Hoz scroll parameter 10/25/2013 Version 16K Added ability to set HLS Sequence MAIN folder NOT under HLS Added sort by Channel Color in Output Added ability to Rename Segments Changed COM Protocol to COM_DMX Added COM_Serial protocol -- no fromt end DMX channel start --- just data Added export/import Animation Faces 10/18/2013 Version 16J Fixed Multi-Dmx channel Export with Dead Channels 10/18/2013 Version 16H Allowed Audacity file to be placed on normal channel Fixed Multi-Dmx channel Export with Dead Channels -- naming in XML file Removed any Fixed DMX channel flags that did not produce dead channels 10/17/2013 Version 16G Added Animation WORK a checkbox Added encryption 10/15/2013 Version 16F Fixed half work done with Fixed DMX Library - 15Y 10/15/2013 Version 16E Added Arrow movements to turn test channels off and on 10/15/2013 Version 16D Select How you wish to Display Segments -- IN Sync or GRAY (out of sync) 10/15/2013 Version 16C Custom PixelPlane Effects can be exported into a series of PNG file 10/14/2013 Version 16B Addedd Debug file for Triggers 10/14/2013 Version 16A Made Prepare Channels for Output to Limit to one Universe Report Dup Chan when if found in output 10/14/2013 Version 15Z Revised Test Outout lights to take Fixed DMX into account 10/14/2013 Version 15Y Added Fix DMX Channel Location to Library Layout 10/13/2013 Version 15X Fixed Manage Output to save universe and MultiDMX to channel Removed single tic ignore from loading audacity file Auto convert NON-RGB channel and effects into RGB if changed 10/12/2013 Version 15W Revised How Segments are displayed 10/07/2013 Version 15U Added Vixen output attrib to outputorder in HLS - Vixen File 10/07/2013 Version 15T Added Vixen output attrib to outputorder in HLS - Vixen Profile 10/7/2013 Version 15S Fixed Internal Dimming Curve File Path 10/06/2013 Version 15R Fixed Master Lighting Effect applied to RGB channels 10/6/2013 Version 15P Revised PrePare to Output - Sort by Name to sort by Universe/Name 10/6/2013 Version 15N Vixed Import Vixen where Vixen and HLS had different Resolutions 10/05/2013 Version 15M Added Grid Refresh as Output is toggled so Grid will show actual effect level being transmitted. 10/05/2013 Version 15L Added Color Shift between two colors NOT using the Color Wheel Expanded the Export CSV file to include additional items. 10/04/2013 - Version 15K Removed the "Channel Number" from the Raw Channel Dialog 10/2/2013 Version 15J Enhanced Group Display - Add to List - by keeping existing Group channell order Enhanced Prepare for Output by having Order sort by Universe and Order 9/29/2013 Version 15G Eye Animation Added 9/27/2013 Version 15F Fixed RGB Dimming Curve Flag Compare 9/27/2013 Version 15E Added additional info to Dimming Curve error msg 9/27/2013 Version 15D Added REST to Animation 9/26/2013 Version 15C Added Dead Channel Capability 9/25/2013 Version 15B Al found that with LED Dancer - Export Play File crashed -- I was processing as RGB - not defaulting to single channel 9/24/2013 Version 15A Removes changes from 14W and 14X since they were not required Fixed Mouth Channel assignment showing all channels assigned to a mouth Added conversion for PNG sequence into hlsPNG effects Added conversion from Custom PixelPlane effects to jlsPPE effects. hlsPNG and hlsPPE effects can be added to PixelPlane or RGB channels 9/23/2013 Version 14X 14W did not work to fix pixel based mouth Segment creation - this one should 9/23/2013 Version 14W Revised Segment creation when used as Mouth channel so don't show GRAY 9/22/2013 Version 14V Added Test for existing DisplayGroup when importing from Library
Madko
Castle Hill NSW
Habbosrus, that's a lot of extra upgrades! It will take a week just to read it all!
No worries will upgrade soon.
jhinkle
Key West, Florida
Rebuild fails when you are not running HLS in Admin mode and a rebuild needs to be accomplish.
XP --- User -- ADMIN.
Win7 -- USER --- ADMIN --- AND Right Click on HLS icon - select "Run as Admin".
We can thank Microsoft for security requirement.
Joe
