Katekate
its pretty stiff, but you would probably get a reasonably tight bend if you warmed it up. it would probably kink if you tried to make it into a candy cane though.
I have made a 1.8m circle prop out of this and was fine. Smaller arches I have made have eventually cracked as they are out in the weather and it does get weak if under too tight a bendWhat sort of bend radius is it possible to make with this? Is the tube quite flexible ?
