Replacement motors
Discussion in 'Cutouts, Wire Frames & Motifs' started by dpavisic, Jan 13, 2014.
  1. dpavisic
    dpavisic Full Time Elf
    May 12, 2010
    211
    0
    Sydney
    I have 4 reindeer and a Santa on a see saw which have all stopped moving over the years. The rope lights now have all virtually blown out as well is it is time to refurbish everything. I was simply going to run new rope light, but haven't done this before, so am after any suggestions from people that have done this before. Also does anyone know if you can get replacement motors for the moving heads etc? I'm really not sure what type of motors I currently have but I think they are 240v as the rope lights are 240v and the motors simply connect to the lights if you know what I mean.
  2. JPB
    JPB Full Time Elf
    May 13, 2010
    334
    11
    Glenwood
    I have used a microwave turntable motor in the past. Worked well.
    I got mine from WES Componants / Wagner at Ashfield. If you look on their website you can find one with rotation speed and shaft length to suit.
    Jon
  3. OP
    OP
    dpavisic
    May 12, 2010
    211
    0
    Sydney
    Thanks Jon, what about waterproofing the motor? I presume that you did this somehow?
  4. JPB
    JPB Full Time Elf
    May 13, 2010
    334
    11
    Glenwood
    I used a jiffy box from Jaycar or similar and mounted it so the shaft and wire existed through lid and then the whole box was attached to the frame with the lid facing down. Not IP68 but definitely rain proof.
    Jon
