Beacy
I have 2 AVD DC48 boards in series that have RGB silicone strip attached to it as well as 5050's.  They are both set up as RGB boards in LSP and are set up in their own universe.   The problem is the 1st board correctly outputs the RGB colours as set out in LSP, however the 2nd board does not .
The outputs set in LSP are
Red - I get green on the display
Green - I get Blue on the display
Blue - I get red on the display
These boards were tested using the DA 1.31 software are outputted the correct colours but when they are put in series for some reason I get these strange colours. It appears that LSP creates the 2nd board as something different. Any suggestions as to how to fix it
