- Thread starter
- #1
Bending
What's a reasonable minimum radius for bending a silicon tube pixel strip (such as sold by Ray Wu and others) - along the less flexible axis? For example, could I bend a 5m stip into a 0.8m radius (1.6m diam) circle? Probably not, but from those of you who have worked with these strips - how small can one make a circle? 1.6m (ie: two 5 m strips for the circle?
(I gather one could cut it periodically and splice segments with 4 wires, but that would interrupt the smooth curve as well as causing waterproofing issues, right?)
Power
The second question is about power. I would think that at 5v, a 5m 150pixel strip @ 60ma/RGB pixel would be over 9 amps full on (including chips), right? Wouldn't that be too much current/heat for the flexible PCB at the feed end, and also have too high a voltage drop at the far end? How long a strip can one really power from one end? Are there tricks?
On the other hand, there are 12v strips. It would naively seem in that case that each controllable "pixel" would need to be implemented as multiple RGB led's, like three in a row that change together, right?
I would like to create a full circle of individually controlled RGB pixels. Smaller is somewhat better. Is that even feasible with pixels strips, or must one use pixel strings and individually place each LED?
Thanks for some pointers, as I migrate towards pixel displays...
Power
