Rookie questions
Hi Gerry,
The only time anything lights up is when I run the test function. Then the two strings connected to first two outputs on the Pixlite and the seven strings running out of the MEGa all start flashing.
Selecting only 511 and running test does nothing. Yes using output to lights.
[attachurl=1]
  • Test Halloween.zip
Hi Gerry,
Interestingly testing the first 300 channels only allows me to run the two strings of 50 nodes that are connected to the first two outputs on the Pixlite board.
However I only get output to the Halloween face (which is off the MEGa60 board through the DMX output on the Pixlite) if I select all channel output.
Hello Andrew,
Need your xlights_* files as well ie the rgbeffects , networks at least - that is where your model definition and setup definition is.
