RPM USB to DMX dongle
Daemon
Napier
Hi
Does anyone know anything about these dongles? I need to troubleshoot my display, my dongle seems to be putting out bad data but I dont know how to test it.
Using vixen 2.1 on a laptop, outputting DMX to a Tiger 48ch dmx board.
Steve
cscool36
Belrose NSW
Hi Steve,
Have you downloaded the driver from RPM and the net driver as well.
I am using the same one controlling 76 channels with his controllers and others ones.
You may need to set the start channel for the tiger.
Hope this helps.
Colin
Daemon
Napier
Hi Colin
Yes I have downloaded the drivers and all installed okay. Including the ftdi driver.
The led flashes properly so it should be all okay. I have checked that I have a USB 2.0 and I have measured the voltage at the dongle and I am getting 5.0 volts.
Besides setting the strating address in vixen, is there another way to set it that you mean?
For example I have set vixen up as channels 1-64 for my ren-c grinch plugin and channels 65-112 with the DMX USB pro plugin.
The com and baud rate etc doesnt matter with this dongle because it is an "intelligent" one so I am not sure what else I could try to set.
Thanks for the answer
