oldmanfathertime1000
Computers, music, audio, video, electronics
I also use LOR & E1.31. I run LOR controllers on a USB dongle & run the ECG-P12Rs on nic card(E1.31)
bhasse said:For those that posted I assume you are still using the LOR sequencer in order to continue to use the USB485B. Any ideas on if I were to use HLS or something else. It appears to me that HLS would not support the USB dongle and I would have to run everything through the network .
ɟɐsʇǝppʎ said:You will need a cross over cable
The presentation shows you how to make a cross over cable which is as easy as just cutting a network cable and then rejoining the coreect wires as shown in this presentation.
ShellNZ said:I then have 3 DMX controllers that I have hooked up (daisy chained) with another USB485 (DavidAVD's one with isolator).
Shanta said:I just want to be sure I'm hearing you right, you are using an LOR USB dongle to drive a DMX network populated with DMX-native devices. I've been looking for info on how to do that and the helpful folks at LOR told me to get an Enttec! Can you point me to more info about how to set it up to do that? Thanks!
Kane said:Shanta said:I just want to be sure I'm hearing you right, you are using an LOR USB dongle to drive a DMX network populated with DMX-native devices. I've been looking for info on how to do that and the helpful folks at LOR told me to get an Enttec! Can you point me to more info about how to set it up to do that? Thanks!
I'm pretty sure that a LOR dongle cannot drive dmx, as it only sends out the LOR protocol
However, most LOR controllers can accept either LOR or DMX protocols, so if you have a DMX dongle, then it can be used with both LOR controllers and any DMX controller
