Scratch built E1.31 80 pixel Starburst
elnino
Hi all, I know this is not necessarily groundbreaking but I thought I would post it here for others to see.
I bought a bunch of WS2812b LEDS (bare chips) on a whim some time back and then realised just how tedious and annoying it is to try to wire them up. However, I have a bit of time on my hands at the moment so I went about making a starburst.
The first thing to consider was how to mount the LEDS. The first thing that came to mind was some transparent 'strip' that I could superglue the leds face down on to and then manually wire the back. I couldn't find anything appropriate laying around in the shed but came accross some 4mm black fibreglass rod I salvaged from an old damaged kite.
I cut them to 8 lengths of 20cm and made up a jig on my CNC machine to perfectly place the LEDS, smear some CA glue on the board side of the leds and then stuck them on:
I grabbed a bunch of cheap ceramic 0.1uf caps for each of the LEDS - At the time I got these because they were cheapest (11c each) but It actually turned out quite convinient. I bent down one leg on all of them, held that to the back and soldered it to the gnd pin of each LED.
I then flipped it over and soldered the other leg to the diagonally opposite 5V pin:
After trimming off the remaining length of the capacitor legs, I used them to link the data pins:
TBC...
After completing all of the links, I then stripped lengths of wire and soldered them down the sides of the capacitor legs for the power:
Finally, After making all 8, I made up a hub on the CNC machine from Acrylic and mounted them. Some more wiring and...
View: http://youtu.be/ekL2u8TyuLQ
Looks good. No video of the CNC machine in action though :(
I agree with David though. You have too much time on your hands. You do appear to be making good use of it though.
The CNC machine is nothing too special but i use it soooo much! It's a great tool to have. It generally only takes a few mins to draw something up in cad and 'print' it out. One of my best investments that's for sure.
I use it for making circuit boards as well as stuff like above.
Cutting Carbon fibre sheet (G27 Paddles for larger wheel):
Speaker panel in a Mini Arcade machine:
and more recently, as a 3d printer...
FYI, Mine is a 3040Z but mine does not have the rotational axis that one comes with (and I paid a fair bit less for mine ~3 years ago)
Correct, It's running from a UNO with ENC28J60 module there but I am in the middle of swapping it to a Pro Mini.
