Hi all, I know this is not necessarily groundbreaking but I thought I would post it here for others to see.
I bought a bunch of WS2812b LEDS (bare chips) on a whim some time back and then realised just how tedious and annoying it is to try to wire them up. However, I have a bit of time on my hands at the moment so I went about making a starburst.
The first thing to consider was how to mount the LEDS. The first thing that came to mind was some transparent 'strip' that I could superglue the leds face down on to and then manually wire the back. I couldn't find anything appropriate laying around in the shed but came accross some 4mm black fibreglass rod I salvaged from an old damaged kite.
I cut them to 8 lengths of 20cm and made up a jig on my CNC machine to perfectly place the LEDS, smear some CA glue on the board side of the leds and then stuck them on:
I grabbed a bunch of cheap ceramic 0.1uf caps for each of the LEDS - At the time I got these because they were cheapest (11c each) but It actually turned out quite convinient. I bent down one leg on all of them, held that to the back and soldered it to the gnd pin of each LED.
I then flipped it over and soldered the other leg to the diagonally opposite 5V pin:
After trimming off the remaining length of the capacitor legs, I used them to link the data pins:
TBC...
TBC...
