chris19681986
- Jan 2, 2021
- Thread starter
- #16
35ft to the start of window run. 7 ft each for the other two runs. Arch run will be about 50 to start. Thank you
I see those arches being a pain with data and power. Cant put a receiver out there and a second power supply? You could run one arch per output and inject the end or run them all off one output with only data and V- and power inject at both ends of each arch
Only reason I hadn't went that route is the outside outlet is on the right side of the garage and then I would have cords over driveway and sidewalk. I could get a small second power supply that is 12v. It would still be in garage and make those arches 12v. Data would still come from the same controller via cat5. Then I probably would have to do so much injection out there. It would 14ga wire out to the arches. ThanksI see those arches being a pain with data and power. Cant put a receiver out there and a second power supply? You could run one arch per output and inject the end or run them all off one output with only data and V- and power inject at both ends of each arch
Gotcha. Well if 14 stranded is to big I could use solid 16 for pos and neg and single strand of cat 5 for dataPoor English on my part. I meant that for the Upper Floor Window and Porch strings, they should drive all right with 14 AWG but using 14AWG for the data wire is larger than it needs to be and that 14 AWG wire is large for the green Phoenix connectors on the Falcon controller. The green Phoenix connectors Falcon uses are meant more for 16/18 AWG wire.
