Setting up your ECG and Madrix for streaming ACN (E1.31)
neilric99
Irvine, the OC, CA
Attached is a PDF on what I needed to do to configure my ECG-DR8 with 6 Slaves enabled and setup Madrix to output using Streaming ACN (E1.31)
Neil
In So Cal
  • Instructions for setting up Madrix to use the ECG.pdf
Perfect...
Very Clear details (saved on my laptop)...
Just messing the boards now...
too impatient... :p
I'm sure it will be better than Eiffel tower flashing lighting 8)
Frenchy Guy.... Henri
Just a little addon hint for you.
I've noticed that sometimes when you go into device manager and change universe setting etc that every so often madrix will display the changes but won't actually make them.. Exiting out and restarting madrix seems to cure that problem, but it is a bit ugly.
the demo will functionally run, but it will stop outputing for 10 seconds every minute. And then will stop outputing completely after 1 hour.
