Shared Sequences?
Thanks, tried to recreate it but it never was as good as the original.
Thanks for the link and thanks for the sequence
CHeers Boof
Yeah I think that dropbox link was the best spot. Not sure if its still the same but at one point is had the audio file already edited so you didn't have to figure out how to do the mix.
Audio file and images etc should still be there in the Dropbox link. [emoji1]
All still there!
oops not quite- animations and music but no actual xml sequence
that i could find??
Thanks if that could be uploaded as well please
Boof63
http://nutcracker123.com/forum/index.php?topic=2175.0
In the first post of the above thread link there are the xml files for the Starwars sequence ( the sequence xml file and rgbeffects xml file) and a Dropbox link to the music and animations.
Edit: to anyone looking at the above link, you won't see the xml files attached to the first post in the link above if you haven't joined the Xlights forum if I remember rightly.
THANKS Logan, i wasn't registered,
so when that comes trough i should be good
CHeers and thanks again for your help
Boof63
I've now copied the sequence and rgbeffects xml files to the Dropbox folder so anyone can grab them from there now .
Ben, I tried to reply to your pm but it wouldn't reply as it said your inbox was full - you are too popular obviously [emoji1]
