single RGB Strip DMX controller
kool-lites
Baulkham Hills
In order to replace the house outline with RGB strips, I need the ability to control individual strips.
Sooooo I came up with the following solution:
full details will be updated here: http://baulkolites.com/wp/?p=618
mmais68569
Ocala, Fl.
I like the looks of those would save a lot of wasted CH. on controllers. I have 42 wasted Ch because the amps are pushing the limit of the controllers. Will these be an item that will be for sale????
Thanks Mike
Robbo
Hastings-Victoria
Have you got power running through the cat5? and I cant see how you would adress these...can you provide more info? oh and as last poster...are they available for purchase?
Not sure if I may need something like this as my load imits are not being pushed at the moment as I have 3 strips on 1 27 channel board from ray taking up all the channels as i split the strip up into segments to give a semi digital look
kool-lites
Baulkham Hills
Start address is set by sending the required address in channel 1&2 from vixen. You then push down the push button and power up the controller. All 3 channels turn on to indicate the address is programmed. You then remove power and off you go.
Once I run in the oven for a whiles I then then see how many I have for sale.
Slite
Mölnbo, Sweden
Oh, I'd prolly buy a bunch of these if they were available. Also like the idea of your 8 channel controller if you plan on making that available for sale :)
/Stefan
