- Jul 13, 2019
Hi,
I am creating a garage matrix this year and with the design it will be split into sections so that we can open either side of the garage when we want too. So on the left side of the garage will be 2 smart receivers feeding 8 string which will be zig zag 6 times with 288 pixels on each string running horizontal from bottom left and on the right side of the garage will be another 2 smart receivers with 8 strings in the same config except they will run horizontal from bottom right. Essentially it will look like one big matrix at the end of the day and that's how I want to model it in Xlights as if it was just a single matrix. I will then create some sub models such as a garage outline, horizontal top, vertical left and vertical right etc.
So in Xlights should I just create one big matrix and then create 2 shadow models that will get uploaded to FPP to reflect the actual configuration (i.e 8 strings on one side and 8 strings on the other side)? Or do I create two matrices? If I create 2 matrices, I would then need to group them for sequencing and I'm wondering if that will create any issues, especially for sub models such as the horizontals.
Thankyou for your input.
