ChristmasLover
- Nov 29, 2012
Pixad8
Now to next next issue...I set the dip switches to off,off,off,on in order to run the test pattern. Rebooted device and it worked beautifully. Only issue now is I can't get the test pattern to stop unless I force the boot loader to stay active.... When I set all dips to off and reboot the test pattern continues to run...
I assume xx00 means all dips set to off. Is there a middle setting in the dips or is it either off or on?
Thanks to all of you who have helped so far with my other issues.
