Timing Highlights in LSP 2.5
Discussion in 'LightShow Pro (LSP)' started by cscool36, Jul 6, 2013.
  1. cscool36
    cscool36 Full Time Elf
    Jan 9, 2011
    158
    0
    Belrose NSW
    I need some help with adding timing highlights onto layers.
    And How do you remove them.
    Colin
  2. fasteddy
    Apr 26, 2010
    6,636
    67
    Use the Highlight in the effects Tab and drag a cross and it will highlight those timings to the colour that you have chosen from the tab that sits just to the right of the play button on the ribbon bar. That will allow you to then see those timings and saeperate those timings a bit like tracks in LOR
    To remove a hightlighted timing then just select the shared timings and then highlight using the shared timings that is selected from the ribbon bar next to the play button.
