Timing Highlights in LSP 2.5
cscool36
Belrose NSW
I need some help with adding timing highlights onto layers.
And How do you remove them.
Colin
Use the Highlight in the effects Tab and drag a cross and it will highlight those timings to the colour that you have chosen from the tab that sits just to the right of the play button on the ribbon bar. That will allow you to then see those timings and saeperate those timings a bit like tracks in LOR
To remove a hightlighted timing then just select the shared timings and then highlight using the shared timings that is selected from the ribbon bar next to the play button.
