1/8" (3mm) Coro flute.zoobmarine said:What material did you use? Did you use a CNC for drilling?
I wanted to keep weight downBumpy2020 said:Wouldn't it have been easier to use peg board ?
It already has holes in a grid pattern
I have made all my other holes for nodes with an iron just as you say and I do get a nice fit but the reheat time is slow sonot bad for 100 odd holes but not 2200. I am getting a good tight fit with the drilled holes.zoobmarine said:If you are going to use nodes I suggest you use 2 sheets of coro, this will keep the node in place always, I used a pencil soldering iron to make holes was very easy, and after heating y placed the node the warm of the hole make it easier to place the node, when it got cold it fixed very good
My fingers agree that strip would be easy but I like the crisp definition of a node.Fasteddy said:your definetly commited, should look great when finished
Im lazy as i would have used strip instead
You win the prize for noticing lol.Christmas @ the Myrtle (Michael) said:Missed one, bottom row centre
