nzlongfellow
Dennis from NZ
The general idea of the spreadsheet and the visual display in NutCracker is to give you an "idea" of what your yard will look like. The models and layout do not have to be perfect so long as when you do your "whole house" model they are drawn "relative" to each other.
Imagine you are unrolling your display and as you unroll you see more and more. And then imagine that as you unroll then what YOU see is what is actually SEEN in your display. If they are revealed out of order then just rearrange them so they are revealed as you want them in real life.
Say an arch starts then 1/3rd through you start to see a tree and that half way thru the arch is half way thru the tree then modify the spreadsheet to represent this.
Hope this helps.
Hope this helps.
