Hexagram
- Dec 30, 2013
Hi team,
Just wondering if this is anything I should be worried about - I have a few strings of icicles from Ray Wu running off a J1 ECG-P12R firmware 3.4b. I've read everywhere that the recommended speed is 3000-3600kbps, however I can only get my strings to work if I set the speed to 600-800kbps and in one case where I've extended the cable by a few metres I had to set the speed to 500kbps and use a null pixel. I have tried everywhere from 1800 - 3600kbps but the strings just go either an aqua blue or white and stay like that. On lower speeds the first few pixels will respond to colour changes... but they change to the wrong colours.
Everything is mostly working - here and there the string that I have extended will stop changing colours on a pixel level and the entire string will start changing colours in unison but that's usually fixed by power cycling the controller.
Cheers guys
Cheers guys
