Thank you for all of your help! I have been scratching my head for the last few days. One other thing, is it possible to output from Xlights to my show without uploading a sequence to fpp? I.e. using the 'Output to Lights' on Xlights.You wont need to connect your laptop to your show network anymore - if you've got it set up as above, anything on your home network can access your show devices.
But if you do connect it, you can use the same DNS server you use on the rest of your home network.
Often your router - 192.18.1.1 - or a public DNS server like:
Google - 8.8.8.8
Cloudflare - 1.1.1.1
Quad9 - 9.9.9.9
Thank you very much!You will need to remove the FPP Proxy configuration from your controllers tab - just specify the IP addresses of your controllers only.
That way xLights doesn't try to involve FPP and your Output to Lights will work fine.
