damona
- Oct 23, 2013
There are other threads about this.
Assume a 8 port switch with wireless network, assume the Controller/Transmitter (e.g. Raspberry Pi) is on port 1
Multicast-ing without IGMP-Snooping Switch
- Packet Multicast Packet received on one port sent to the other 7 ports and the wireless network.
- Effectively the same as broadcasting
- All Devices hanging off the switch, need to process the packet i.e. open it up and determine if an action is required. Each individual device will have a limit on how many packets/actions it can process without dropping any packets/actions. You could assume a E.131 design to support a single Universe would not need a lot of cpu/chip processing power and big maybe might be the first device to drop packets/actions.
Multicast-ing with IGMP-Snooping Switch
- E.131 Device now and then should send a packet to say I am interesting in hearing about these multicast packets with these Multicast IP address. The switch builds up a table of Multicast IP address to Switch Port. e.g. it would learn Port 2 is DMX Universe 10, Port 3 DMX Universe 5, Port 4 DMX Universe 6, Port 5 DMX Universe 15, Wireless DMX Universe 5,9&3. (not that you want many DMX universe on wireless)
- Effectively Unicast (really bad way to put it)
- If a Multicast IP address does not have a mapping (because the device did not send out the I want to hear this), all ports will get the Multicast Packet.
I Recommend the LinkSys LGS308 Switch. 8 Ports and 12VDC 1amp, so you can spread your switches around the house/yard. If you are running 12VDC you can then use the same power supply as your lights use.
Wireless ADSL Router (not connected to ADSL/Telephone) i.e. use it as a DHCP Server and a Wireless access into Raspberry Pi so you can upload your new shows.
[SIZE=x-small]Wireless ADSL Router, one port only ->[/SIZE] (port 1) LinkSys LGS308
-> (port 2) Raspberry Pi (output)
-> (port 3-7) E131 Devices
-> (port 8 ) Second LinkSys LGS308
The assumption here is the old ADSL route does not support IGMP Snooping i.e. do not plug a Multicast-ing Raspberry Pi into it directly
