Using E1.31 and OpenDMX in the same sequence
ewanh
what goes here?
Caldermeade, VIC
Hi,
I have LSP Advanced and having issues getting it to output to E1.31 and DMX at the same time.
I can write/run sequences for either the DMX controllers or the E1.31 controller, but not both. I have DMX configured for Universe 1 and E.131 on Uni 2,3,4 and 5. Is there a trick/tweak required to get them to play nice together?
This is the second year in a row I have run small tests with LSP and it has worked, but failed for the actual show. Not enjoying it very much.
Ewan
I just tried adding a USB (Open DMX) dongle to my existing LSP sequence (that uses E1.31) and it works as expected.
I can see the E1.31 data (using SACNview) and USB DMX data (using a DMX Pro dongle) being output simultaneously.
Maybe there is a conflict of universe or zone numbers or maybe the LSP release you're using has a bug? I have version 2.5.4650.19419 of LSP sequencer installed if that helps.
