Vixen 3.1 Questions
aaronwa
Perth
Hi Guys,
I have sat down and creating very basic sequences with vixen. For example using 5 "set level effects" 20% increase in brightness its a "fade up"
Is there anyway to save these custom effects into a library, or a quick menu for saving, and inserting? or do i have to rely on copy and paste?
adski
Dave Brown
Two Wells, SA
If you want a "fade", use the Pulse effect. After placing it on the timeline, double-click on it to edit it, and then click on the Intensity Curve box to edit the fade characteristics (the default is a fade up from 1 to 100% over the length of the effect).
[attachimg=1]
You can drag the blue square handles to create the shape you want (contol-click to add a new handle). When you're happy with it, click Save Curve to save it in the library.
Dave
davrus
Silent elf
Whitianga
Presently, you can't save defined effects. The workaround is to have a sequence where you save them, and from where you can copy paste to the target sequence. (You can have more than one sequence open at the same time - but they must all be in the same profile. There is no way to copy and paste stuff from a sequence in one profile to a sequence in another profile)
Presets and colour collections can be used across sequences.
damo1271
Adelaide
I find the preset intensity curves useful if you have an intensity curve that you use regularly. Lets say you use the complicated "M" shape that Adski drew all the time. Simply place the effect, then right click and then select your required preset curve from the collection item and it magically applies the defined intensity curve to the effect. :)
