Release Vixen 3.4 Update 1 Now Available
ChristmasInKaralee
Karalee
Update 1 has now been released for Vixen 3.4.
This release is cumulative and includes a few important fixes we didn't catch in time for the previous release. This is now considered the stable release
Click here to download
** Bug
* [VIX-2156] - Edit time glitch
* [VIX-2157] - Delete key in the editor randomly quits working.
* [VIX-2163] - Vixen crashes when dragging color from set level to color preset library
* [VIX-2164] - Profile stays locked if there is only the default profile and Vixen does not shutdown cleanly.
* [VIX-2169] - Display setup image buttons have annoying background hover color change.
* [VIX-2172] - If a sequence is resized smaller and there are effects beyond the end of it, they are not removed and can cause issues later on.
* [VIX-2173] - The level slider on curves that are part of a gradient level pair will not stay active to grab and use them.
** Improvement
* [VIX-2158] - Improve the way current preview templates are handled.
* [VIX-2159] - Change selection border color for dragboxfilter effect images
* [VIX-2160] - The find effects function could have a column to indicate what layer the effect is in.
* [VIX-2161] - A few more areas need high DPI fixes.
* [VIX-2166] - Add hints in the Dimming curve setup to use a library curve. Add link to website for help.
* [VIX-2176] - Enable multi edit on the depth of effect property.
* [VIX-2178] - Create a means in the display setup to rename elements with a find and replace style mechanism.
Vixen 3.4 Update 2 Coming soon.
The following are already in the builds so feel free to download and use those as they are stable at the moment with bug fixes and a few extra features.
Update 2 will include:
Improvements
VIX-2008 - Right Click context menu on the Preview form. Ability to lock position, hide border, reset size, always ontop and hide status bar
VIX-2186 - Add Snowflake build up at the bottom of a matrix/megatree. As flakes hit the bottom they remain and build up as more flakes land on top. Gives the appearance that snow is building up.
VIX-2189 - Add shortcut keys to reverse the colours in the Gradient on the effect editor. Select shift+alt+left mouse click in the gradient will reverse the colour gradient.
Just in case you missed it in Update 1 you can now add custom templates with automatic element linking. Check this on the US forum has a great video on how too.
Fixes
VIX-2183 - Fix issue where module file would corrupt if Vixen was closed too quickly. Will remain open after close until module file has completely been saved. IMPORTANT FIX
VIX2193 - Fix issue if you managed to zoom in on the timeline too far.
