Mike
CLAP infected!
This is a list of IP ratings (Ingress Protection) for quick reference.
First number
Please be aware that some of the stuff coming out of China do falsely claim that is a certain IP rating such as IP67. Check them out first before using.
First number
- Protection against > 50mm object size such as whole hand, Ball etc
- Protection against >12.5mm object size such as fingers or smaller
- Protection against > 2.5mm objects such as tools or thick wire
- Protection against >1mm objects like screws, nails etc
- Protection against Dust, BUT may not entirely be prevented. Can not cause sufficient interference to the operation of equipment
- Protection against Dust- full protection , dust tight
- Protection from dripping water
- Protection from dripping water at an angle of 15 degrees from its normal position
- Protection from spraying water at any angle up to 60 degrees from the vertical
- Protection from splashing water at any angle
- Protection from water jets (6.3mm nozzle) at any angle
- Protection from powerful water jets (12.5mm nozzle) at any angle
- Protection from non continuous immersion up to 1m
- Protection from continuous immersion beyond 1m -depth specified by manufacturer
