Where to run power for rooftop lights
thewanderingpine
So most of my lighting plans are pretty modest the next season or two. But I was looking to wire up some strips in a channel along the gutters of the house - probably just running off an esp32 running wled for the first little while (I'm experienced enough with these - using them for the occasional indoor/decorative project).
Where I'm a little bit unsure -- we're adding a second story at the moment. So the walls are currently empty and I have an electrician adding GPOs. For running a simple controller for lights on the house/roof -- where should I get the power? I was wondering about getting a GPO in the attic or an outdoor rated one under an eave. Is that worthwhile - or should I put it somewhere else?
G'day mate, you're only thinking of installing one!?
You've got the golden opportunity to install as many as you may need/want for the future. Think about all possibilities for which you may need gpo's not just for Xmas lights. Think about running data cable for a home network, home automation? Check out SuperhouseTV on YouTube as he installed a lot of extra cables while his house was being renovated.
While it's all open it's a heck of a lot cheaper to do it now rather than later.
Cheers Bazzy
I'm running a ton of internal cat6a. Not quite superhouse level though.
I'm certainly running a bunch of extra indoor power points, smart switches, etc. I *think* I've got most of those covered. (power on basically every wall, in most of the cupboards, etc).
I guess what I was thinking was -- for things like rooftop lighting -- *where* should the extra power be located?
:thumbsup: "where" will most likely be dictated by how easy it will be to plug anything into them being up top of the 2nd story. If you put a GPO inside the attic then how easy will you be able to thread the plug from your appliance back inside?
If it were me I'd put weatherproof ones on a side wall right up under the soffit and back from the corner 300mm+(1foot). The GPO would be easily accessible via an extension/step ladder.
