Al mentions a possible issue with a missing neutral causing issues, but I don't agree. With the Australian "MEN" system, a fault like that can't really cause an issue. If it does the RCD will trip
Interesting. Haven't heard of the "MEN" system. (Would like to learn about it.) I agree that the RCD should shutdown the whole thing, but what timing is on that?
Either way, I have never installed that jumper and won't without good cause.
MEN System - Everything You Need To Know — Electricians Success Academy | Start, Scale & Automate Your Business
What is the MEN system installed across Australia to ensure electrical safety? How does it function and why it is important? In this article, you will learn about the Multiple Earthed Neutral system -- a crucial component of electrical installation and safety in Australia.electricians-success-academy.com
RCD are supposed to trip in 30ms or less, if 30mA of current goes missing.
The RCD SHOULD trip.
Unfortunately there are always exceptions, also if you have an older house, you may not even have rcd's installed yet.
I recall when I was a kid getting a "tingle" everytime I went for a shower off the taps, this got worse until finally my dad called the electric company and found a faulty neautral wire at the meter box.
There was also just last year a girl that got electricuted from touching the garden tap.
So SHOULD is the appropriate word.
Now as far as the wiring the dc to ac. Not something that I would do. First as we all know there is resistance and therefor voltage drop over any length of cable, This applies to the earth side also. AC by it's nature creates ripples or harmonics which is introduced into the earth and neutral (or be it small) Now if you add this to the dc negative and are trying to run data as we do at very small voltages, then any harmonic introduced into the dc side as far as I am concerned is going to be a problem if you are trying to fault find some weird data issue.
