Wixel-32 Pre-Order - Group Buy Is Live!
The esp32 unity branch of espixelstick firmware does support sd card yes.
Tryed loading it up last night an got this error,
there is no sdcard attached to the esp32 tho.
Any chance of where i went wrong?
Code:
ESPixelStick v4.0-dev (NOT STABLE)(May 12 2021 - 05:08:43)
ESP Version: v3.3.5-1-g85c43024c
Flash File system initialized.
Listing directory: /
'/config.json':     '284'
Listing directory: /www
'/www/alexa.html.gz':     '134'
'/www/artnet.html.gz':     '407'
'/www/ddp.html.gz':     '130'
'/www/disabled.html.gz':     '130'
'/www/dmx.html.gz':     '474'
'/www/e1_31.html.gz':     '406'
'/www/effects.html.gz':     '589'
'/www/esps.css.gz':     '13499'
'/www/esps.js.gz':     '57138'
'/www/fpp_remote.html.gz':     '423'
'/www/gece.html.gz':     '517'
'/www/index.html.gz':     '3078'
'/www/mqtt.html.gz':     '839'
'/www/relay.html.gz':     '495'
'/www/renard.html.gz':     '526'
'/www/serial.html.gz':     '632'
'/www/servo_pca9685.html.gz':     '523'
'/www/ws2811.html.gz':     '1492'
No SD card installed
Configuration File: '/config.json' reading 284 bytes.
Configuration File: '/config.json' loaded.
*** 'Disabled' Initialization for Output: '0'***
*** 'Disabled' Initialization for Output: '1'***
*** 'Disabled' Initialization for Output: '2'***
***Configuration File: '/output_config.json' not found.***
***Configuration File: '/output_config.json' Could not read file.***
EEEE Error loading Output Manager Config File. EEEE
--- WARNING: Creating a new Output Manager configuration Data set - Start ---
*** 'WS2811' Initialization for Output: '0'***
*** 'WS2811' Initialization for Output: '1'***
************** Cannot Start WS2811 for channel '2'. **************
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x40173bce  PS      : 0x00060930  A0      : 0x800ea97c  A1      : 0x3ffb1db0
A2      : 0x00000001  A3      : 0x00000000  A4      : 0x3ff50000  A5      : 0x3f40305a
A6      : 0x00000064  A7      : 0x00000065  A8      : 0x80173a0c  A9      : 0x3ffb1d90
A10     : 0x00000000  A11     : 0x00000000  A12     : 0x3ffbea10  A13     : 0x0000ff00
A14     : 0x00ff0000  A15     : 0xff000000  SAR     : 0x00000008  EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000000c  LBEG    : 0x4000c349  LEND    : 0x4000c36b  LCOUNT  : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x40173bce:0x3ffb1db0 0x400ea979:0x3ffb1de0 0x400ea98d:0x3ffb1e00 0x400e73e5:0x3ffb1e20 0x400e86f5:0x3ffb1e80 0x400e8d25:0x3ffb1ef0 0x400e8d7f:0x3ffb1f30 0x400d3f6e:0x3ffb1f50 0x4010755a:0x3ffb1fb0 0x4008a956:0x3ffb1fd0
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5856
entry 0x400806a8
