D deblen Full time elf Joined Mar 20, 2011 Messages 153 Nov 18, 2015 #1 Hi, Has anyone able to share their STL file for a WS 2811 led smart pixel node clip I have tried making one, but seem to get the dimensions wrong. Thanks in advance. Deblen
andrewa Full time elf Generous elf Joined Dec 22, 2012 Messages 279 Location Frankston North, Victoria Nov 18, 2015 #2 What are you wanting to clip to, I have made clips for 2811 bullets to go onto round pipe as per attatched is that any good to you? Attachments IMG_1168.jpg 1.4 MB · Views: 43
AAH I love blinky lights :) Community project designer Joined Dec 27, 2010 Messages 4,406 Location Eaglehawk Nov 18, 2015 #3 I had a mate draw me up some and there's a thread on https://auschristmaslighting.com/threads/mega-tree-pixel-clips.7919/ That's what they look like in the flesh (I believe)
D deblen Full time elf Joined Mar 20, 2011 Messages 153 Nov 18, 2015 Thread starter #4 Hi, Andrew, if possible a copy would be great, as I was trying to get it fit to 8 mm rod, I tried with the thread from Alan, but kept coming up with odd size. Thanks
andrewa Full time elf Generous elf Joined Dec 22, 2012 Messages 279 Location Frankston North, Victoria Nov 19, 2015 #5 This is where I created the clip https://tinkercad.com/things/kCSW2JyBCD6 In tinkercad, it will allow you to modify it to your own needs click the link, and then click on tinker this the smallerring is the pixel, so just change the diameter of the larger ring [attachurl=1] Attachments pixel_clip_25mm_nb_gal_pipe_to_12mm_bullet_pixel_cable_notch (3).stl 22 KB · Views: 7
D deblen Full time elf Joined Mar 20, 2011 Messages 153 Nov 19, 2015 Thread starter #6 Hi Andrew, Thank you, when I opened it up in Tinkercad, to see howe the clip was designed, made it easy to understand how it was done. Thanks again, Deblen
adski Dave Brown Joined Feb 15, 2012 Messages 203 Location Two Wells, SA Nov 19, 2015 #7 This one seems to work: [attachimg=1] [attachimg=2] https://dl.dropboxusercontent.com/u/99720285/3D%20Designs/pixel_clip_12-8-a.stl Attachments Pixel Clip 12-8.jpg 26.8 KB · Views: 119 2015-11-19 12.00.57a.jpg 39.7 KB · Views: 122
D deblen Full time elf Joined Mar 20, 2011 Messages 153 Nov 19, 2015 Thread starter #8 Hi Dave, Thanks Deblen.
plasmadrive Full time elf Joined Jan 12, 2012 Messages 248 Location Elk Grove, CA Nov 19, 2015 #9 Are these all 3D printed? How does the plastic hold up in the sun or cold?
adski Dave Brown Joined Feb 15, 2012 Messages 203 Location Two Wells, SA Nov 19, 2015 #10 That issue has crossed my mind. I'll tell you in a couple of months time.
