videoman3857
Our soil is clay and rock hard so it should be ok.
I have the same .............Have fun digging.
Looks good. Might I make a suggestion. Add 1 or two hooks/supports for guy wires at the back. You will be surprised at the weight in these pixels and all pulling on one side will eventually bend/bow it, if not make it difficult to put up and down.
Geoff. Where did you get the topper for your tree made? Looks like quality work.I ended up getting the 50mm x3.2mm x 6.5m Gal pipe and a winch.
This is the topper I had made up, just doing a 180 degree 36 string for now.
Looks the real deal and plenty of hooks too. I'm looking for ideas on a wind-up pole for next year. I'm getting too old for lifting heavy stuff.From Hughes Fabrication and Welding on Cooney Street Ipswich. Any Welding guy should be able to make one up. I just handed them a very detailed drawing and they built it from that. I also got the wheels from ebay.
How did you go with concreting in your base?
Join the club. I'm going winch next year also.I'm getting too old for lifting heavy stuff.
3 ways.so as long as I can find the spot
3 ways.
- Put a small irrigation "spotter box" over it and just lift the lid when ever you want to put up the tree.
- Triangulate the hole from two permanent points .. write down the measurements on the pole with permanent marker
- Use a metal detector.
Nice work Geoff - will definitely stand out.I set up the Mega tree today..
