Release 2024.01 Released
keithsw1111
Kellyville, NSW
2024.01 Jan 17, 2024
— change(dkulp) Move repo to xLightsSequencer org, update headers and url locations
— enh (dkulp) Auto-Build in xCode cloud, initial setup for TestFlights builds
— enh (keith) Limited support for RGBWW pixels
— enh (derwin12) Use rest for missing face phoneme
— enh (tygunn) When a ruler is defined, show the X/Y/Z coordinates of models in the models export
— bug (Scott) Clear test presets when switching show folders
— bug (dkulp) Hopefully fix crash on macOS when changing audio devices
— bug (dkulp) Use BitmapBundles for icons in Import Dialog (HiDPI updates)
— bug (scott) Fix upload to WLED if different pixel types are used
— bug (cpinkham) Fix compile with gcc 13
Issue tracker: https://github.com/xLightsSequencer/xLights/issues
  • Like
Reactions: AAH
Is the upgrade notification broken in xLights? Running 2023.23 and do not get an update notification when I open the application.
I tested my version at home 2023.20 and it is not notifying about updates either.
It appears the xLights website is broken.
The table of previous releases is not showing either.
I imagine it all stems from that as xLights reaches out to http://xlights.org/releases to get the list.
things have changed on github too. (see first entry on these release notes) so that may also cause the update checker to fail out.
Github redirects quite cleanly when a repository is moved; all previous links still work; unless if the previous owner stands up a new repository with the same name as the old.
Packet capture definitely shows xlights reaching out to the releases page on xlights.org; however,and not to GitHub specifically.
