Release 2024.11 Released
Status
Not open for further replies.
keithsw1111
Kellyville, NSW
2024.11 Jun 15, 2024
– enh (dkulp) Add ability to set display names for Model/Submodel layers
– enh (dkulp) For VSA import, set the layer name to mach the servo
– enh (dkulp) Add effect background for Servo Effect
– enh (dkulp) Make Servo effect easier to use for common “Ramp” use cases by not requiring the value curves for those
– enh (dkulp) Make sure preview honors the min/max configured for the servo
– enh (dkulp) Change MovingHeadPanel to use dialog units and/or default sizes for buttons
– enh (gil) Show Active Timing Marks in Moving Head Effect Dimmer Panel; Only set MH channels that have actually been changed
– enh (dkulp) Allow Canvas mode effects to set pixels transparent (ex: shaders only applying to part of buffer)
– enh (cybercop23) Sort Model Icons + swapped Download & Import
– enh (cybercop23) Removed Wreath model from being created
– enh (scott) Added Timing Event Bar Bounce to VU Meter
– enh (derwin12) Ability to order the views in the Display Editor window
– enh (cybercop23) Add Aliases for Models and Groups to the Export Model
– enh (cybercop23) Layout Panel – Remove start/end channels for shadow items, MH type
– enh (cybercop23) Add quick open base button
– enh (cybercop23) Sort dropdowns for In/Out Transitions
– enh (PeteMatthews) Add sACN/ArtNet support for ILightThat controller
– enh (cybercop23) Stack button on ctrl page and remove the slider to prevent full close of right panel
– enh (derwin12) Allow for a model vid export to be done at high or lowdef render via scripting
– enh (derwin12) Add middle mouse to pan sequencer
– enh (derwin12) Check that timing track name doesnt conflict with models
– enh (derwin12) Show Set Center Point dialog for all groups
– enh (cybercop23) Move Delete to lower in thej list to reduce accidental click
– enh (derwin12) Optionally retain the effect duration when duplicating an effect
– bug (derwin12) Keep buttons visible in submodel dialog
– bug (gil) Fix Pan value curve
– bug (derwin12) Model groups with one model causing stalling/crashing
– bug (MrPierreB) Bars effect – Fix bug where the highlight color is not used when other layer blending options are selected
– bug (gil) Fix model paste when no model is selected
– bug (dkulp) Fix ValueCurve bottom not being visible or selectable on Mac.
– bug (dkulp) Some fixes for colored buttons on sonoma having their sizes changing
– bug (dkulp) Make sure sorting is turned off during the model list “Freeze” and re-enabled on “Thaw”
– bug (dkulp) FireEffect: only call GetMaxBuffer during init, use that size throughout the effect rendering for consistency
– bug (scott) DMXEffect – some more fixes after update to 48dmx channels
– bug (gil) Fix major bug with MovingHeadEffect on groups…it was triggering all heads whether they were selected or not
– bug (gil) Fix Sketch panel resize
– bug (keith) Fix some E4-S Mk3 controller issues with v1.5 firmware, zig-zag, content-type
Issue tracker: https://github.com/xLightsSequencer/xLights/issues
If you have encountered a specific issue, developers ask that you submit details to the xLights GitHub repository.
For requests for general help among peers, consider starting a new forum thread: https://auschristmaslighting.com/forums/xlights-nutcracker.61/post-thread
Status
