3D Printed Silhouette
A couple of weeks ago someone posted in a FB group about a Grinch silhouette so I get one 3D printed and tested it. The small floodlight gave a blurred result due to the large reflector in it. It really needed a point source light (a small LED torch in this case) to get the sharp definition. I'll have to try the same floodlight with the reflector removed for the next test.
That's kind of cool. I like it.
Those floods have 3 leds of each color? I wonder if you blocked two of the rows if you'd get a distinct shadow. Obviously lower light output and potentially higher heat problems. Non red, green or blue colors would still cause a similar problem but you would have a 3 color shadow you could play with. I also wonder if a diffuser would help or if it would just scatter the light even more. Finally, wonder if you replaced the reflector with a torch reflector if you'd get better definition.
Blocking some of the rows may improve it in one axis, but you'd still have the blur in the other.
Getting the source area down to a single smallish LED will be the way to go. I'm checking what 2W or 3W spots are available on AliExpress.
