4 Core Security Cable 7/0.20 White
Discussion in 'Christmas Light Shopping Bargains' started by gmoolenaar, Nov 11, 2013.
  1. gmoolenaar
    gmoolenaar New Elf
    Dec 27, 2012
    25
    1
  2. David_AVD
    Jun 12, 2010
    3,986
    275
    That size would be ok for very low current items such as Big W strings, but too thin for pixels. The larger one (14/0.2) is better for most applications but is more expensive of course. I think "Electricians Warehouse" has 4 and 6 core 14/0.20 security cable at pretty hot prices.
  3. DeeJai
    DeeJai Is that Magic Smoke?!?
    Oct 18, 2011
    1,007
    0
    No longer in Radelaide
  4. David_AVD
    Jun 12, 2010
    3,986
    275
    Yeah, that's a pretty hot price Matt. It seems to have a thinner outer sheath than the Altronics one, but perfectly fine for Christmas lights. :)
  5. Beacy
    Beacy It's so much better on the dark side
    Jun 10, 2010
    467
    1
    Beaconsfield
    Ive used Altronics once - never again 10 days for the stock to arrive
  6. damo1271
    damo1271 Full Time Elf
    Oct 12, 2011
    200
    6
    Adelaide
    Building Technologies Online has a webpage and you can pick up if you're local:
    http://www.bt-online.com.au/cable/
    They have very good prices and I've bought a bit of cable from them - all pick up direct from shop. Smartalec put me onto them.
  7. fasteddy
    fasteddy I have C.L.A.P Global Moderator
    Apr 26, 2010
    6,639
    70
    I buy from the same guy but in a 300 metre roll and use the 14/020
    http://www.ebay.com.au/itm/Security-Cable-6-Core-14-020-305m-Box-White-Accesss-Control-Security-Cable-/251149064833?pt=AU_Television_Accessories&hash=item3a79a69a81
    I originally used the 7/020 from altronics a few years back but the cable I linked to above seems far better value and has a higher current capacity
  8. DanJ
    DanJ Full Time Elf
    Aug 14, 2013
    184
    0
    I was planning to use some 20 gauge T-stat cable (locally available from Home Depot) for about a 60' RGB run. Is this security core wire 14 AWG? That seems really "heavy" for RGB apps (?). Thx.
  9. David_AVD
    Jun 12, 2010
    3,986
    275
  10. adski
    adski Dave Brown
    Feb 15, 2012
    203
    4
    Two Wells, SA
    It's Metric - 14/0.20 = 14 conductors each 0.2mm diameter - about 21 AWG
    Dave
  11. DanJ
    DanJ Full Time Elf
    Aug 14, 2013
    184
    0
    Ok. Thx Dave. Appreciate the info. I am planning to use a 14 AWG/5 conductor cable . I figured I could double up on power conductors if needed in case I have nuisance voltage drop..
  12. David_AVD
    Jun 12, 2010
    3,986
    275
    If you ever have just one extra wire, use it to double up the ground (-ve) instead of the +ve.
  13. dpavisic
    dpavisic Full Time Elf
    May 12, 2010
    211
    0
    Sydney
    Why double up the ground? I'm sure there is a reason which I don't understand.
  14. Charl Marais
    Charl Marais For my twins was the excuse I started with.
    Jun 27, 2013
    187
    0
    Secunda
    Your signal cable references ground so with reduced resistance on the ground line you have improved signal definition as a bonus and still get the current rating you were looking for.
  15. David_AVD
    Jun 12, 2010
    3,986
    275
    To clarify; I was talking about pixel strings.
    There's two electrical paths sharing the ground; the power to run the LEDs and the data reference.
    Excessive drop in either ground or V+ will lead to duller lights, so doubling either would be an advantage.
    Excessive drop in the ground wire will also introduce a shift in the received logic levels that pixels needs to receive reliably. Doubling the V+ wire will not help, but doubling the ground wire will help.
    So, doubling the ground wire helps both ways, but doubling the V+ (only) helps in only one way.
    Now, if we're talking about "dumb" RGB strings, doubling up the common wire (usually the V+) is e way to go as that's the wire that has the sum of the individual (colour) currents.
